Overview
This program is much the same as File Synchronisers, however it utilises the command prompt to copy relevant files and folders. It allows you to list the files before copying them to a new directory.
Description
The program uses a producer consumer architecture, and queues. The user can select the type of copy that is performed (Copy data only or Mimic).
Copy data only will copy new data across, but will not mirror deletions. No files or folders are deleted.
Mimic will exactly mirror the base folder to the target folder. Any files or folders that are created, modified or deleted in the base directory are mirrored to the target location.
The mode type can be changed using the switch at the bottom of the front panel.
1) Download the VI
2) Select a base directory
3) Select a target folder
4) List files / folders or Copy the data
Requirements
Software
LabVIEW 8.6 or newer
Windows OS
