Example Code
File Path Checker - helping to prevent file/folder overwrites - Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows your code to automatically detect if a specified file or folder already exists.
Description
This simple little SubVI allows your code to automatically detect if a specified file or folder already exists - and if it does exist the algorithm adds an incrimentally increasing interger to the end of the filefolder path, until it is unique - thereby, preventing you overwriting any files/folders.
Requirements
  • LabVIEW 2012 (or compatible)
1. Run the VI once - it will create a Folder called Test Sub Folder in the Application Directory, and the Path Modifed? LED will be off.
2. Run the VI subsequent times, and the VI will detect that the Test Sub Folder already exsists, and will create a Test Sub Folder1, Test Sub Folder2, Test Sub Folder3 instead. The Path Modifed LED will be on.
VI Snippet
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Comments
Fuzzy Me
Member
Member
on
This VI will not incremant in sequence with last increment. ie if test sub folder 2 selected next should be
test sub folder 3 and not test sub folder 21
