Example Code
FieldPoint Continuous Acquire and Graph
Code and Documents
Functional Description
This VI is a slight modification of the Analog Input.vi.  That VI simply outputs an array of values from the fieldpoint channel you select.  This VI builds those values into a waveform and displays that waveform on a waveform chart.
Justin Parker
Product Support Engineer
Contributors
