Example Code
FPGA Sawtooth Wave Generator IP
Code and Documents
This set of IP lets you generate a 16 bit or 32 bit sawtooth wave on LabVIEW FPGA. I have included VIs that you can run on Windows or RT to generate the integer parameters based on floating point inputs for amplitude, range, and frequency.
Contributors
