Example Code
FPGA - Pulse Train Generation Using LabVIEW
Products and Environment
    Hardware
  • CompactRIO|SingleBoardRIO
    Software
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
  • LabVIEW
    Driver
  • NI RIO
Code and Documents
Overview
This example uses LabVIEW FPGA to generate a continuous pulse train of a variable frequency and duty cycle. The pulse train is generated on the FPGA and is output from a cRIO digital output module.
Description
Pulse train A repetitive series of pulses, separated in time by a fixed and often constant interval. The duration of each pulse and its duty cycle are also often made constant. In this example we are generating a digital continuous pulse train of a variable frequency and duty cycle. The pulse train is generated on the FPGA and is output from a cRIO digital output module.
Requirements
LabVIEW 2015 or compatible
LabVIEW 2015 FPGA or compatible
LabVIEW 2015 RT or compatible
NI RIO driver
  1. Open the cRIO Pulse Train Generation LV2015 NI Verified Project
  2. Configure the CRIO IP and connect
  3. Compile cRIO Pulse Gen (FPGA) VI
In the cRIO Pulse Gen (Host) VI
  1. Provide the compiled FPGA VI bit file in the Open FPGA VI Reference function in the block diagram
  2. Enter Resource Name, Frequency and Duty Cycle
  3. Run the VI
cRIO Pulse Gen (HOST) VI Block Diagram
 cRIO Pulse Gen (FPGA) VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Dan King
