Overview
This example allows to switch between two waveforms without stopping generation.
Description
This example builds on the shipping example Fgen Arbitrary Waveform.vi. It allows you to switch between two waveforms without stopping generation. By writing the second waveform to memory while the first waveform generation is active, the second waveform will be generated when the FGEN card regenerates from the memory that has been overwritten. This can be useful for FGEN cards that do not support scripting or streaming (such as the PCI/PXI-5412) and need more waveform data than can fit on the memory of the card. This example should work on the 5412, 5421, 5422, and 5441.
Requirement
Software:
Labview 2012 (or compatible)
NI-Fgen driver which is compatible with your hardware and version of LabVIEW
Hardware:
NI-Fgen device
1. Select the name of your Fgen device
2. Run the VI
Block Diagram
