Overview
This example VI demonstrates how to read a .RTF file and convert it to a LabVIEW string visualized on the front panel.
Description
In LabVIEW you are able to use .NET controls to import files with .RTF extension and convert them to the LabVIEW string format thanks to the use of property node. A while loop inside of the block diagram is used to keep the Rich Text Box populated with the text extracted from the Rich Text file. A file with extension .RTF is given in the attached compressed folder and can be called thanks to the File Dialog Express VI, allowing the user to programmatically select a Rich Text file.
Requirements
VI Block Diagram
