Example Code
Extract PDF Text and Search using PDF-Box
Code and Documents
Overview
This example VI demonstrates the use of functions in .NET pallete to extract or search for string in any PDF file.
Description
This is a fairly simple example for those who just want to extract and search the text of a PDF. It uses some third party software found at the following link:
 https://sourceforge.net/projects/pdfbox/files/
Special thanks to Dan Letecky for providing his .NET examples upon which this is based. See the link followed for his article which allowed this to exist:
http://www.codeproject.com/Articles/12445/Converting-PDF-to-Text-in-C
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " PDF Text Extractor.vi"..
  2. Choose a file path and input a string. In the bottom half of the screen, you can play your "new sound," save it, or stop the program. The table lists all the signal types that have been added to it.
  3. Run the VI.
VI Block Diagram
Comments
B_Strange
Member
Member
on
Thanks for this. I will be using it to automate some data extraction.
If you receive this error: "An error occurred trying to load the assembly."
Try the following: In Windows 7 or later, you also can right-click the assembly and click Unblock on the General tab to grant an assembly full trust. I found this here.
