Example Code
Export Graph to Word Using Report Generation Toolkit for Microsoft Office In LabVIEW
Products and Environment
    Software
  • LabVIEW Report Generation Toolkit
  • LabVIEW
Code and Documents
Overview
This VI provides a simple UI in which the user can specify data to output to a Microsoft Office Word document.
Description
Running this VI will output a graph to an unnamed Word document. User inputs allow the data to be selected, the default values entered into the array are a basic sine wave.  The UI also has inputs for basic graphing settings for the plot colors, axis settings, etc.
Requirements
  • LabVIEW 2013 (or compatible)
  • Report Generation Toolkit for Microsoft Office
  1. Download the attached VI.
  2. Enter your plot data into the "2D Array Data" array or use the default data.
  3. Run the program and inspect the MS Word document for format.
  4. Adjust graph settings as needed.
VI Block Diagram
