This example demonstrates how to export a screenshot of a graph/chart or the complete Front Panel to the clipboard.
Description
It is sometimes useful to export a screenshot of a graph/chart or the full Front Panel to the Windows clipboard for documentation purposes. LabVIEW is able to export the data to the clipboard if you use the picture class.
This example provides a ready-to-use SubVI which you could use in your application and a Main VI to demonstrate the functionality.
Requirements
Software
Hardware
For sending strings of characters to the clipboard see KnowledgeBase 4SSFET1V: How can I Programmatically Access the Clipboard From a VI?
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
To have this work in a subVI, you'll need to change the VI properties to "show front panel when opened" and then "close when finished". Also, set the window transparency to 100% so you can't see the VI when it's opened. This is to get around an issue that is described in this discussion forum:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=426022&view=by_date_ascending&page=1
-Jack
