Example Code
Execute String/Numeric Querry Using Data Finder Toolkit in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to build a simple String and Numeric Query using the DataFinder APIs in LabVIEW.
Description
This example shows how to build a simple String and Numeric Querry. Note: Data Finder toolkit will only search through the File, Group and Channel properties within a file (not the actual channel data). The current configuration allows you to search for files where the Operator Name is "Steve" or check for channels with a "Max Value" greater than 50 property (you would have to calculate and create this property when you write the file).
Requirements
  • LabVIEW 2012 (or compatible)
  • DataFinder Toolkit
  1. Download the attached files to your computer
  2. Open the VI "Simple Data Finder Query LV2012 NI Verified.vi"
  3. Select the DataFinder reference
  4. Select the query options from String Query and Numeric Query boxes
  5. Run the program
Additional Notes
If you run this example on your computer it will not likely find any files if you have not created files with these specific properties.
VI Block Diagram
Simple Data Finder Query LV2012 NI Verified.pngSimple Data Finder Query LV2012 NI Verified.png
