Description
This is just a simple implementation of a Two Way Stream API. You can use this to more easily implement communication with a remote system. It is based on Network Streams.
This example code can also be used as a reference for you to learn how to encapsulate data into LabVIEW classes to create an API for any function.
Requirements
Software
LabVIEW 2013
Network Streams installed on the remote system
Hardware
NA
Additional Images or Video
For new applications you should consider using Reconnecting Network Stream - OOP
