Description
Description-Separate-1To split a waveform into two parts from a threshold with different colors on the same graph in LabVIEW, you can use the attached VI.
Description-Separate-2How to Use
How-Separate-1First, acquire your waveform data and pass it into the Get Waveform Components "data" input. Then, 1. Checking if the signal's 'Y' component is higher than the Threshold, if so it should add that value or add a 'dt' time interval into the Build Waveform Y component input array, which will build a new waveform on the top of the threshold. After cutting the waveform from the threshold, it merges the 2 waveforms into one.
How-Separate-2Additional Information
Additional-Separate-1The LabVIEW code is written in version 2023 Q3. I will attach the code for the following versions:
- LabVIEW 2023 Q3
- LabVIEW 2022 Q3
- LabVIEW 2021
If you require the code for a previous version, please comment below and I will respond promptly.
Additional-Separate-2
