Example Code
Event versus Polling in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This code allows the user to realize about the performance of the Events and the Polling.
Description
Event Structures are often the most efficient method of creating a reactive user interface.  This VI demonstrates the difference in CPU usage between polling for user input in a loop and using an Event Structure to respond to events.  Run the VI and choose not to use the Event Structure , then pull up the Task Manager in Windows and monitor the CPU usage.  It should max out one CPU core.  Choose different buttons and see the reactions.  Then choose to use the Event Structure, and see the CPU usage drop, but notice that the buttons respond just as quickly.
Requirements
LabVIEW 2012 (or compatible)
  1. Run VI
  2. Watch the Task Manager and see the CPU difference
  3. Click on Use Event Structure to switch between Event and Polling
Event-Driven Programming (LabVIEW Help)
Event-Driven Programming in LabVIEW
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Comments
robert.hovakimyan
Member
Member
on
that is not honest... you will see the same result putting 0 Event Timeout . Otherwise you should add 50 timing delay in False case, which also bring to a same result.
