Example Code
Event Triggering Example Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This Event Triggering Example, begins acquisition on Nth trigger event.
Description
This example shows how to skip a certain number of trigger pulse before starting acquisition. This is called "event triggering" since we are triggering on the Nth trigger event.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Configure a counter to divide down the TTL signal wired to its source output.
  2. Use the output of this counter as the trigger source
VI Block Diagram
Kevin S
