Overview
The code attached is a simple example of using an event structure with the scroll wheel on the user's mouse.
Description
This VI detects that the mouse wheel has been scrolled up or down and displays this on a row of LEDs on the front panel. The mouse wheel can be chosen by right-clicking on the event structure and choosing "Edit Events Handled by this Case". In the edit events window you will find "Mouse Wheel" under "Panes>>Pane".
Requirements
Steps to implement or Execute code
VI Block Diagram
