Example Code
Event Based Numeric Slide Bar in LabVIEW
Code and Documents
Overview:
This VI exemplifies how use a value change update event to update an indicator.
Description:
This VI takes a more advanced approach on a very simple concept.The VI contains a numeric slide bar and a numeric indicator. However, the slide bar doesn't directly correspond to the indicator. Instead, whenever the slide bar is changed, it causes an event that changes a local variable. The local variable changing then causes another event to happen where the numeric indicator is changed.
Again, this VI is a very simple concept with the added functionality of the event structures.
Requirements:
LabVIEW 2012 or compatible
Steps to Implement or Execute Code:
1. Run the VI.
2. Change the value of the slider and verify that the value of the numeric control is update. A change on the numeric control should update the value of the slider.
Additional Information or References:
Snippet 2069.pngSnippet 2069.png**This document has been updated to meet the current required format for the NI Code Exchange.**
Chris Van Horn
