Overview:
This is an example that can log the status of the error cluster to聽 disk from LabVIEW or LabVIEW RT.
Description:
This VI demonstrates how to use ActiveX methods to save a Word or Excel report as a PDF. This can be useful for generating reports that cannot be edited by the end-viewer. This VI saves the file as "LabVIEW Save.pdf" in the same directory as the source report. You could easily modify this VI to be used as a subVI with the file name of your choice.
Requirements
LabVIEW 2012(or compatible)
2. Enter a comment into the Data to Log string control if desired
VI Snippet
Overview:
Description:
Requirements
VI Snippet
