Overview
This example demostrates a method for alerting the user of an error without interrupting your program's operation.
Description
This would be useful when you expect to receive an error that would normally require the user to select "continue" in order for the VI to keep running, and will instead ignore the specified error code, set a boolean indicator to true, and erase the error code to allow the VI to keep running.
Requirements
VI Snippet
Hi
This is a way, with a lot of prior knowledge of what the users response would be. ![]()
But please connect the ErrorHandler input before the Erase.
Gabi
You are so very right, oversight on my part. Thanks!
For the application this was created for there was a very specific error code that was expected. Using that error was the best method to notice a change in the environment without interrupting a portion of the program (it WOULD interrupt another portion).
Nice, ChizzDizzle. You might also want to check out the Structured Error Handler Reference Library.
