Example Code
Error -2147352571 When Reading Excel Data in LabVIEW Using ActiveX
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This example covers how you can fix error -2147352571 from the Variant To Data Function in LabVIEW when reading cells which include an error such as #DIV/0. The example is applicable when you are reading data from a Microsoft Excel sheet using ActiveX.
How to Use
Error -2147352571 can be caused by a data type mismatch. Please try to change the data type that you connect to the type terminal of the Variant To Data Function.
An example program is attached below. If you try to convert variant data read from Excel cells which include error #DIV/0 into a string array, error -2147352571 will occur. But, if you try to convert the variant data into a numeric array, you can avoid the error.
Related Links
Using ActiveX with LabVIEW - LabVIEW Help
