Example Code
Encoder Velocity Measurements and the NI 9361
Code and Documents
Description
This example demonstrates how to continuously acquire velocity measurements using the NI 9361.
  1. Change the Counter Physical Channels and Input Terminal as necessary.
Refer to the NI DAQmx Help for the valid channel names for the Counter module.
Block Diagram Steps:
  1. Create a Frequency Task to measure the speed of the encoder.
  2. Create an Angular Encoder Task to measure the position and direction of the encoder.
  3. Configure the Timing and Triggering for the Task.
  4. Start the Task.
  5. Read the Frequency and Position of the Encoder. Use the direction of the encoder in order to change the Frequency into a velocity measurement.
  6. Stop the task, clear the task, and Display errors (if any).
I/O Connections Overview:
For instruction on how to connect your signals to the NI 9361, refer to your device documentation.
Note:
This example is not valid for two pulse encoders, X2, or X4 encoding.
Requirements
Software
DAQmx 14.5
Hardware
NI 9361
Rob W.
Contributors
