Example Code
Enabling Digital Filtering Using Dummy Counter
产品和环境
本部分要求填写创建该范例所需的产品和操作系统。
如要下载NI软件(包括以下所示产品),请访问ni.com/downloads
    硬件
  • Data Acquisition (DAQ)
    软件
  • LabVIEW
    驱动程序
  • NI DAQmx
代码和文档
添加附件
Description
Overview:
Demonstrates on enabling digital filtering on any PFI line on an M Series DAQ Device by using a Dummy Counter.
Descriptions:
When acquiring digital signals in an industrial or otherwise electromagnetic noisy environment, it is common to see some bounces on the acquired signals whenever the signal changes state. These bounces appear as extra pulses close to the actual transition of a digital signal. When processing digital signals for pulse counts such as a quadrature encoded value, it is desirable to avoid theses bounces or eliminate them before processing the signal. This type of filtering or processing is commonly called debouncing as it removes the bounces from the digital signal.
Digital filters (digital debounce filters) can be implemented on the device's PFI line(s) to eliminate noise, unexpected, inaccurate, or incorrect counts on any counter tasks with sensors like the encoder.
On National Instruments M Series (62xx) DAQ Devices it is possible to enable digital debouncing filters on PFI lines used in Counter tasks.
This example program configures a Dummy Task for the purpose of enabling the debouncing filter.
The PFI Line will continue to use the filter until the device is reset or the filter is disabled explicitly (due to the "Lazy Uncommit" behavior of NI-DAQmx).
Refer to these links for more information:
  1. Debounce Digital Filtering with NI 62xx M Series and cDAQ
  2. How Do I Remove Glitches From My Digital Input or Output Signal?
Requirements:
LabVIEW 2012 or compatible.
NI-DAQmx 15.5.1 or compatible.
Steps to Implement or Execute Code:
  1. Specify all the control on the front panel. For M Series devices the valid values for the minimum digital pulse width are 0s, 2.56ms, 6.425us and 125ns.
  2. Run this VI.
Block Diagram Steps:
  1. Creates an analog input voltage channel.
  2. Sets the parameters for the input terminal of the counter and enable the digital filtering on that trigger source.
  3. Calls the Start VI to start the acquisition. Also, commit the task so that the specifications that were made will be applied to the counter input, without actually starting the acquisition.
  4. Calls the Clear Task VI to clear the task.
  5. Uses the popup dialog box to display any error or warning.
John Passiak
NI社区“代码范例交流区”(Example Code Exchange)中的代码范例已获得MIT许可
