Example Code
Emotiv Emostate and EEGlogger sample program with LabVIEW
Code and Documents
I replaced  example9: Emostate and EEGlogger in Emotiv Research Edition SDK v1.0.0.5-PREMIUM  with an example vi by making a new dynamic link library.
For building the dynamic link library: Labview_Emotiv_emostate_EEG.dll and the example vi : labview_emotiv_emostate_eeg.vi, I used  vc2008 express, LabVIEW2011 sp1 Spring 2012, and Windows7.
Before  starting  labview_emotiv_emostate_eeg.vi, please change the file path of emostate and EEG in emotiv_connectf.vi as you like it. The default path is the same location of  emotiv_connectf.vi.
Please put edk.dll and edk_utills.dll  in the same folder  including Labview_Emotiv_emostate_EEG.dll. This VI writes  Emostate data and EEG data  to spread sheet format files.
User number of the first dialog in the labview_emotiv_emostate_eeg.vi must be 0.  In the labview_emotiv_emostate_eeg.vi given by the  Labview_Emotiv_emostate_EEG.dll,  the user number  is fixed as 0,
because  of  making the program easily.
I made the VI so that it looks for the DLL in C:¥LabVIEW_emotiv_emostate_eeg.
Please extract the contents of the updated ZIP file into C:¥LabVIEW_emotiv_emostate_eeg.
This way, you will have the same folder structure as mine.
Comments
Dsy
Member
Member
on
Hi Hideok34
I am having trouble using the dll I place them as the following
And copy the edk.dll and edk_utills.dll same folder as the Labview_Emotiv_emostate_EEG.dll
And also change the path in the Library Node
However, I recieved this error
Any help on this is appreciated Thanks
Contributors
