Example Code
Emotiv EmoComposer Read Smile Example
Code and Documents
Overview
This example uses the Emotiv Brain Computer Interface API to read the smile state of the user.
Description
In order to use this, be sure to download the API from here: https://decibel.ni.com/content/docs/DOC-18059.  This example makes use of the emotic headset.  The emotiv headset is a wireless EEG system that measures brainwaves. It allows programmers to use brain activity in their applications. The basic API allows you to access Facial gestures, Emotivional states, Headset data like the gyro, and trained Cognitive actions.
This VI works by creating a Emotiv task and reading the smile state from an Emotiv Read.
  1. After installing EmoComposer from Emotiv's website, input the path to the edk.dll file in the install directory
  2. Create a data acquisition task for the Emotiv Headset
  3. Connect to the EmoComposer
  4. Acquire and display whether the EmoComposer is simulating the user Smiling
  5. Close the connection when the task is done
Requirements to Run
Software
LabVIEW 8.6 or higher
VI Package Manager by JKI
Emotiv Toolkit for LabVIEW
Emotiv software shipped with headset
Hardware
Emotiv headset
Saline solution
Additional Images
Block Diagram
- Regards,
Beutlich
Contributors
