Example Code
Edit and Insert New Line in Label Text Programmatically Using LabWindows
Products and Environment
    Software
  • LabWindows/CVI
Code and Documents
Description
Overview
If you need to change the text of a command button, text message, or other label at run time, you can use the SetCtrlAttribute function.  If you need multiple lines in the text, use the special character "\n" to insert a new line, such as in the following line:
SetCtrlAttribute (panelHandle, PANEL_INSERT, ATTR_LABEL_TEXT, "Press\nthis\nbutton");
Description
This example demonstrates how to change the label of a command using a callback function. The SetCtrlAttribute function allows the user to edit many different properties, but in this example the Label Text property is selected. Clicking the button toggles the label from one line to three.
Requirements
Software
LabWindows/CVI
  1. Download and unzip the example program.
  2. Open createLine.prj.
  3. Run the program and click on Press this button.
  4. Note the new lines that are inserted in the button label text.
  5. Press the button again and note that the new lines are gone.
  6. Inspect the insertLine callback to see the SetCtrlAttribute function.
