Overview
This example shows one way of referencing the controls in a cluster to adjust their properties or value.
Description
In this example we are using the To More Specific Class function wo specify properties of a specific data type within the cluster. For this example to work you must know what data types and order the controls are in your Cluster. You can also use a For Loop to filter through the controls and use a case structure to determine the datatype if you would like the program to be more modular for different data types.
Requirements
Software
LabVIEW 2013 or later
Additional Information or Reference
