Example Code
Earthquakes program for Data Dashboard Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to use data dashboard by using variables to communicate
Description
This example is based on LabVIEW variables to build communication between Host PC and data dashboard on ipad.
Requirements
  • LabVIEW(2012 or compatible)
On PC:
  1. Open the attached LabVIEW Project.
  2. Build the web service by right-clicking the Build Specifications and then selecting Build All.
  3. Deploy Web Services by right-clicking on the Earthquake Web Service and then selecting Deploy
On iPad:
  1.  (Optional) Use the Retargeter Application to update the dashboard's server location
  2.  Open the dashboard.
  3.  Update variables if Step 1 was skipped.
  4. Run the application.
  5. Scroll right to view a map view
  6.  Scroll right again to view a list of the strongest earthquakes by event ID.
**This document has been updated to meet the current required format for the NI Code Exchange.**"
Allison M.
ni.com/support
