Overview
This is a simulation program of ECG of PQRST complex when they vary what will be the disease
Description
In this code, ECG PQRS complex is simulated and varied automatically, if there is something wrong with the ECG signal, it will report out.
Requirements
Front Panel
Hi I have a question regarding the real time signal analysis of ECG signal. So basically I am using NI USB 6218 for LabView signal Processing. For getting the ecg data for real time I am using the ADInstruments TN1012/ST Pulse Transducer. Also I have used Mini 8 Pin DIN female panel mount which soldered with wires for the communication with the BNC cable of NI USB 6218. Basically, the pulse transducer is connected to this panel mount and soldered with wire and then the ECG signal is passed with real time. But the problem I am facing is I am not able to get the proper ECG signal. Can you help me if this setup is right or wrong in order to get the ECG signal. I am attaching the setup with the photos. Thanks for your help.
Panel Mount
Panel mount soldered
Pulse transducer
Panelmount+Pulse transducer connected
Full setup
