Overview
When using an array of strings, each cell is restricted by the properties of an array. That is, each element of the array must have the same properties. Elements of a cluster, however, are able to have independent properties, but a cluster is not resizable in the way an array is. This example shows how a cluster can be altered to appear as an array, yet have the capabilities of a cluster.
Description
This VI performs the following operations:
1. A cluster containing many string controls is initialized and each string is hidden.
2. When the user hits "BUILD", the strings are made visible and resized according to the dimensions of the string array defined by the user.
Requirements
Even though listed as 2011, the files in Resize Strings - 2011 cannot be opened in LabVIEW 2011. Please provide a LV 2011 compatible version. Thank you.
Hi pbuerki,
Are you unable to open the VIs, the project, or both?
Which errors are you seeing?
Thank you for your reply.
It is the whole project that does not open: "LabVIEW: File version is later than the current LabVIEW version."
Hi pbuerki,
I went ahead and uploaded another version that should work with LabVIEW 2011. I believe the dependent controls within the VI library could not be automatically converted for use in 2011, so I saved them as separate controls and can be found under the "Dependencies" section in the project.
Please let me know if it works for you.
Hello EccentRick,
Thank you. I can now open the project in LV2011 and run the VI. This is a nice piece of work!
Thank you.
EccentRick <web.community@ni.com> wrote:
EccentRick commented on the document
"Dynamically Resizable Cluster of String Controls"
To view all comments on this document, visit: https://decibel.ni.com/content/docs/DOC-39320#comment-40560
