Example Code
Dynamically Build a Simple Array
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Arrays are used to store data in a new and organized fashion. Someimtes they can be a a little tricky to manipulate to get just the way you want them to be. One solution is to make an array of a set size and fill in the values. While this process helps with memory allocation, it does not help us with creating an array that we do not know the size of. This is a simple example that should how to create an array dynamically.
Description
This example uses a shift register, build array and the random number generator to create a 3x8 array. The first collumn is a random number, the second clumn in the interation count and the third colum is a constant. There is a Wait Until Next ms Multiple timer in there to slow down the excution. This VI can be implimented with a While Loop instead of a For Loop.
Steps to Impliment and Execute
1) Download the VI
2) Observe the block diagram. Notice how the shift register is connected to the build array.
3) Run the VI and observe how it fills the array collumn by collumn
Requirements
LabVIEW 2010 or later to run VI
LabVIEW 2012 for code Snippet
Block Diagram Code Snippet
Kurt P
Automated Test Software R&D
