Overview
The purpose of this code is to allow the user to convert from Dynamic Data to a 2 dimensional array of doubles and back to Dynamic Data, and display the data on a chart.
Description
The purpose of this code is to allow the user to convert from Dynamic Data to a 2 dimensional array of doubles and back to Dynamic Data, and display the data on a chart. The example is saved below for LabVIEW 2012. You can manipulate the array of doubles after converting from Dynamic Data, and then set dynamic attributes after converting back.
Requirements
1. Configure DAQ Assistant
2. Run the VI
VI Block Diagram
When I run this example, the real time on x-axix does not work properly. Let's say when only a minute is passed in real time, the x-axis shows a period of several hours!
