Overview
This example VI show a way to dynamically call different producers depending on the hardware you want to use (or in the case of the demo, what waveform you want to generate) by encapsulating the producer into a subVI.
Description
The producer consumer design pattern is one of the most useful patterns we have for DAQ systems. Sometimes it can be useful to have the same code for a DAQ system even if you are using different hardware. There are two key elements make this technique work, one is that use an interprocess communication method which can work in subVIs (e.g. queues, notifiers, FGVs), local variables will not work, the other is that the data interface (both the connector pane and the format of data in the queue/notifier/FGV) must be the same so the consumer can interpret it. If this is extremely difficult you could have an FGV that does the hardwork but having a different set method for different data sources but then formats the data the same for the get method used by a consumer.
Notes: there is another technique available for this. This example works well as long as we can isolate our DAQ code into a single subVI and there isn't too much hardware independent code repeated across the different producers. If you do need better integration of the code but still achieve hardware abstraction then object oriented programming (OOP) can help with this. There are many resources for this in the NI Center of Excellence. There is a fantastic white paper discussion of the technique at http://www.ni.com/example/31307/en/ .
Requirements
VI Block Diagram of "Main Application.vi"
Description-Separate-2
