Example Code
Duplicate for all Cases
Code and Documents
Overview
This package allow you to duplicate a case for every value in a case structure with an enum as a selector.
Description
Each time you create a state machine, you probably had to click several time on the duplicate case menu of a case structure in order to duplicate one frame.
With this package, you can do it in one click only.
-Install the package.
-Restart LabVIEW.
-The principle is to connect an enum constant or control to a case structure. Then display the case you want to duplicate. Right click on the case structure and left click on "Duplicate for all Cases"
Requirements
Software
LabVIEW 2015
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Comments
Olivier_L
Active Participant
Active Participant
on
Hi Sabri,
I didn't load your package yet, but I have a question:
Does it duplicate only for empty cases? or for all cases, whatever is already coded ?
Olivier L. | Certified LabVIEW Developer
sabri.jatlaoui
Active Participant
Active Participant
on
Hi Olivier_L, It will duplicate the visible case and what's inside it. It will only be duplicated for the the case that are not already added to case structure. The ones that are already present do not change.
Regards.
Contributors
