Introduction
Now you can easily control the direction and speed of an NXT brick using 2 motors. This is done simply with the User Interface of the LabVIEW front panel.
Steps to Complete
Connect motors into ports A & B and communicate to the NXT using Bluetooth. Deploy the NXT code and run it, then run the Host code and play with the front panel to drive your NXT module.
can you explain me step by step how to connect the NXT to LabVIEW? I connect the NXT to a bluetooth adapter to run the program but does not detect it. Can you give me a manual or a code of how to do that?
Greetings! ![]()
Hi, i have download your program, NXT_drive run on nxt brick and PC_drive run in labview target on pc, but the nxt brick not responding. The nxt brick is connected to pc and the NXT application browers work.
