Example Code
Draw your own fractal using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to use computers to represent abstract fractals by calculating and evaluating functions recurrently and assigning a color representation for each result..
Description
Here is a brief description of the example:
Program to draw a Julia set fractal (n=2)
This program evaluates f(z) = z^2 + c with z = X+Yi and c = A+Bi  being X,Y,A and B real numbers. This program iterates using:
Xn+1 = (Xn)^2-(Yn)^2 +a
Yn+1= 2(Xn)(Yn) + b
The resulting image has  1920x1080 pixels (a value that can be increased or reduced). The program uses IMAQsetcolorpixel.vi from the Vision Developer Module and Vision Acquisition Software for Labview 2014.
Requirements
  1. LabVIEW 2014 (or compatible)
  1. Assign a value for Xmax, Xmin, Ymin, Ymax, M (radius), a and b.
  2. Choose the color spectrum to show how divergent or convergent each function evaluation is.
  3. Run the program.
  4. Change the size of the image by changing the N terminals of each for loop and the input terminals of the IMAQ create.vi.
VI Snippet
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
Comments
alexderjuengere
Active Participant
Active Participant
on
Nice! Using the colortables found here und the While Loop's R instead of Y to index those colortables, your vi is rendering somthing like this:
EFranz
Member
Member
on
I really like it, thanks for sharing!.
I  modified the code to generate the following image based on the code I found here.
VI saved as FRACTALrender.vi
Hope you like it.
Erwin Franz
MarcDub
Active Participant
Active Participant
on
Great VI. I played with it for while and ended up adding some UI features. It is posted at Draw your own fractal 2
Marc Dubois
www.harotek.com
Marc Dubois
