Example Code
Download An Image From A Website And Show It On A LabVIEW Frontpanel
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to download an image from a website and show it on the Frontpanel.
Description
It is sometimes handy to show an image from a website on the Frontpanel. To do so, you need to download the image from the website and show it in a LabVIEW picture control. There is no out-of-the-box function for this use case, so you have to implement the function by yourself.
You can use the DataSocket Read.vi or the HTTP VIs to download the image. This example use the HTTP VIs, because this VIs can store the image into a file without additional VI calls.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached VI
  2. Run the program
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Comments
Jokelnice
Active Participant
Active Participant
on
good VI, served me for an application of an IP camera that had not been resolved
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
kirsch
Active Participant
Active Participant
on
It's frustrating that you need to save the file to disk only to read it back in and display it. Does LabVIEW really have no way to display a JPEG coming from memory?
Marcos Kirsch
Chief Software Engineer
NI Driver Software
