Example Code
Display all Folders and Shortcuts in a Directory Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows users to select a directory and display all of the folders and shortcuts within that directory.
Description
This example displays the shortcuts and folders within the directory as well as the absolute locations (resolved paths) of the folders and shortcuts. This example can be used to simply show the user a list of all folders or shortcuts within a directory.  It can also be modified to programmatically select every folder and shortcut within the directory and perform some sort of task on each.  For example, it can open all of the files in each of the folders and shortcuts.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the directory of the folder.
  • Run the program
VI Snippet
Justin D.
