Overview
This VI shows how to disable the control signal to a device if a measurement from the device falls outside of a user-specified range.
Description
This VI takes a device control signal (a boolean) and a numeric value. The VI compares the numeric value against a user-defined range. If the value falls within the range, the VI outputs the current value of the device control signal. If the value falls outside of the range, the VI outputs a false value for the device control signal. By default, the lower limit of the threshold is included in the range, while the upper limit is excluded.
Requirements
NOTE: If the user wants the comparison happen continuously, the user should place this code within a loop.
VI Block Diagram
