This example shows you how to take differential measurements using National Instruments two-channel high-speed digitizers and NI-SCOPE.
Using the built-in NI-SCOPE math functions, you can quickly and easily get a differential value without having to manually take the data from two single-ended measurements and perform the subtraction. The attached code demonstrates how to carry this out.
Description-Separate-2
How-Separate-2
