Overview
This example is used to create a sub-vi that will output the input arrayed data at different rates using one clock on an E or M series DAQ device.
Description
Although E or M series DAQ device will both output at the configured rate, the sub-vi will allow the array to be scaled to output the data at an effectively different rate. This can come in handy if you need to acquire data at a faster rate than you need to output data when controlling using a NI DAQ card.
Requirements
VI Snippet
