Example Code
Detect largest incoming value or data
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates a method of displaying the largest incoming value into a control on your front panel.
Description:
This VI takes the incoming data, compares it to previous information and if the value is larger it displays the data on the front panel control. In addition to displaying it on the front panel it also stores the value in a shift register.  If the value is not larger than the previous value, then the previous value is still displayed on a front panel and the value in a shift register is still the previous value.
Instructions:
To implement this example:
  1. Download the VI
  2. Run the VI as is or use it as SubVI
  3. Observe the Current Value and Largest Value on the front panel
  4. Stop the VI when finished
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Mahdieh G
National Instruments UK&Ireland
Comments
jordankuehn
Member
Member
on
There is no need for a local variable here.  See the attached VI Snippet with minimal changes to the example.
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
MahdiehG
NI Employee (retired)
on
Thanks for the suggestion. That was a classic mistake there, oops.
Mahdieh G
ThanhDong
Member
Member
on
Hi MahdiehG,
There is also a various method using Max&Min VI to find the  largest value
It is shown below
Dong
