Example Code
Detect One-Directional Boolean Value Change using Polling
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to poll the value change of a button to true.
Description
This VI shows how you can execute a block of code when a boolean control is change in one direction without using an event structure.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Detect Boolean Value Change Polling LV2012 NIVerified .vi - Front Panel.pngDetect Boolean Value Change Polling LV2012 NIVerified .vi - Front Panel.png
Detect Boolean Value Change Polling LV2012 NIVerified .vi - Block Diagram.pngDetect Boolean Value Change Polling LV2012 NIVerified .vi - Block Diagram.png
Notes
You can use this same method for any data type, just set up the boolean logic to the need of your datatype.
 **The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
Priley
Member
Member
on
A small added simplification, replace the 'not equal to' and the 'and' logic with a single 'greater than'
Priley
Member
Member
on
oh and...replace the 'on-loop' shift register and initialising with the new-ish shift register (left arrow) wire the switch into its initialisation input too.
