Example Code
Detachable Run Button - A XControl Example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This example uses the power of an XControl to create a detachable Run Button.
Description:
When placed on the Front Panel of any VI, the control will replace the VI's existing Run button and run the owning VI when clicked.
To try this out on your own, simply unzip the attached files, open up the project and the 'Tester.vi' and then click the run button on the front panel to run the VI.  If you would like this functionality on one of your own VIs, simply click and drag the included XControl onto your Front Panel.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI, clicking the Arrow.
2. If you would like this functionality on one of your own VIs, simply click and drag the included XControl onto your Front Panel.
Alternate steps: this functionality is surprising easy to implement on your own.
1. Create a new XControl.
2. Add code to the Init.vi to hide the control label, resize the control to a suitable size, and hide the owner VI's Run Button.
3. Next, add a boolean control to your Facade.vi and give it the appearance of your chosing.  (You might want to use the Advanced>>Customize functionality.)
4. Then, add a Value Change event for that boolean and use the refnum in the Container State control to programmatically run the Owner VI when the value change occurs.  This works because the Value Change event will fire even if the Owner VI is not running.
5. I also added code to the Exec State Change case to show or hide the control depending on the state of the Owner VI.
Additional Information or References:
