Example Code
Delete Listbox Row without Affecting Format of Other Cells Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI programmatically deletes a row from a multi-column list box while maintaining the formatting of the other cells.
Description
Properties such as background color, font, etc. are properties of each cell. If a row is deleted and all items are shifted up by one row, the cell properties do not automatically shift with the text. However, this can be accomplished using property nodes for the list box. To test the code, set Row to Delete to a row that currently exists in the list box. Since it is zero-indexed, the first row is row 0.
Requirements
LabVIEW Full Development System 2012 or compatible
1.Run the VI.
2. Notice that the selected row is deleted, and all other items keep their original formatting
VI Block Diagram
Delete Listbox Row without Affecting Format of Other Cells LV2012 NI Verified BD.jpg
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Jennifer R.
Comments
amithkuttan
Member
Member
on
