Overview
This example prompts for a file and for the letter of the column to delete.
Description
Using the Excel ActiveX Server, you can open a reference to an Excel spreadsheet and delete a given column. It saves the file to the same location/filename with " - modifed" added to the file name using regular expressions.
Requirements
VI Snippet
I'm just wondering, how does one create an application refnum. In this case it is Excel.Application, where did it come from?
Ok, sorry it's simple. Insert an automation control on the front panel or auomation refnum on the block diagram. Right click and select activex class.
Hello!
i have few doubts,
1. i am not able to find excel.application:
i right clicked on input of automation block and click on browse. I am not sure how to select excel.application.
2. with the example you provided, i am not able to select properties for property node. Here are the images i came accross.
I had the same issue where Excel.Application was not showing up in the type library even though Excel came pre-installed on my laptop. I resolved it by going to my Office365 page and selecting the "Install Office" link. I'm not sure if it made a difference, but I also chose to install office with the same bitness (32 vs. 64) to match my LabVIEW install.
