Example Code
DOT MATRIX (see your name in lights!!) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI demonstrates loading a bitmap image (8 or 24bit colour depth) and displaying it with a 2D array of LEDs.
Description
Loading a Bitmap file gives a 2D pixel map. After calculating the average intensities for the square of pixels represented by 1 LED, convert the 2D array of average intensities to a 2D array of Booleans. This is accomplished by comparing against a threshold value. The F10 button is used to stop the application. The Stop button is outside of the viewable screen and associated with the F10 button.
Requirements
  • LabVIEW 2012 (or compatible)
1.Pop up to allow user to select colours for the Dot Matrix
2.Load the bmp file
3.Convert the 1D array of pixel intensities from the Bitmap into a 2D pixel map
4.Determine the average intensity for the pixels represented by 1 LED
5.Convert the 2D array of average intensities into a 2D array of Booleans
VI Snippet
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Comments
alpha1
on
That's an awesome community example Rich! Thanks!
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
GrahamG
on
Sweet App!!
Clever use of the differing formats of bmp files - this could come in handy in many more serious applications too
And as you say seeing your name in lights  does give a special thrill, Today LabVIEW, Tomorrow Broadway, Next week - THE WORLD!!
Graham Green
Software Product Marketing
NI | Emerson
Mark_SAI
on
Awesome simple app Mr R, great for showing someone the basics of many ideas (Clean UI, simple algorithms, code commenting) I may have an application for this! (Best compliment is copying someones code and all that...!)
Great VI Icons, good commenting, nice use of the Application Directory primitive, clean user interface, everything I'd expect from a RR masterpiece!
But where is the love for the error wire/error case structure (particularly in ColourSelector.vi?! ) You show love for it in the Bitmap loader vi...   hehe.
theno1dj
on
Any chance of having this to work with 8.5??
Cheers
RER
NI Employee (retired)
on
Hi Theno1dj, I have just added a version of the code saved in LabVIEW 8.5.
Enjoy!!
Rich Roberts
