This example performs a simultaneous analog output generation and analog input acquisition utilizing the DAQmx Trigger Start Delay property node using NI-DAQmx with support for LabVIEW NXG.
The acquisition is triggered off the start of the analog output task after a delay of 10 ms. This is done using the DAQmx Trigger "Start Delay" property node. The analog output and input operations are running on their own independent clocks, which can be set to different rates.
Such a delay could be useful when data is not expected to become significant until a certain amount of time after the trigger. In a stimulus-response application, for example, the acquisition data is not significant until the UUT has had enough time to respond to the stimulus.
1. Select the appropriate Input Physical Channel and Output Physical Channel that correspond with the physical wiring on your device.
2. Set the AI Rate to determine the sample rate of acquisition.
Note: This should be at least twice the frequency of the signal being generated.
3. Select the AO Rate to determine the rate of generation.
4. Select what type of signal to generate and the signal parameters.
