Example Code
DAQmx TDMS Data Logging - TDMS File Splitting
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example works to split the data between multiple filesas Comb filters when logging data using DAQmx TDMS logging.
Description
When logging data using DAQmx TDMS logging, splitting the data between multiple files can make file sizes more manageable. TDMS file splitting was first supported in DAQmx 9.3. TDMS file splitting is enabled with the use of a property node.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Configure the parameter for the right channel and device.
  2. Connect your hardware appropriately.
  3. Run the VI.
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
