Overview
This VI starts and stops the generation of a continuous digital pulse using a software trigger.
Description
This VI is a modification of the Gen Dig Pulse Train-Continuous.vi example. A case structure and while loop were added around the DAQmx Start.vi. The case structure is controlled by the Start button on the front panel so the user can start the task with a front panel button. When the task is started, a true constant causes the while loop to exit. The stop button is then used to stop the task.
Requirements
Software
Hardware
Additional Information and References
Front Panel
Block Diagram
