Example Code
¿Cómo puedo hacer mi Waveform chart y/o graph dando un clic sobre la misma en LabVIEW?
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This VI exemplifies a way to increase the size of a Waveform indicator responding to user events.
Description:
This VI uses the Mouse Down event to increase the size of a waveform indicator adjusting it to the pane size. It also uses a "Restore" button "Value Change" event to restore the original size of the indicator. This action could be really helpful to show just the desired graph to the user and provide more details depending on the situation. This could also be applying to other kinds of indicators and controls.
Requirements:
LabVIEW Base Development System 2012 (or compatible).
Steps to Implement or Execute Code:
1. Open the attached VI "Expand Graphs LV 2012 - NI Verified.vi".
2. Run the VI.
3. Click over any of the four waveform indicators to increase its size.
4. Click the "Restore" button to return the waveform indicator to its original indicator.
Additional Information or References:
